Solar value instead of %
Ohmigod, this is way too much fun for $20 :lol:
Would it be possible to get a choice of actual solar (w/m2) instead of % in a future version?
At the moment it's only a % in the clientraw feed from WD. I'll see if Brian can make it available.
Julian
I guessed that might be the case.
I noticed (2.01) that some of the tag names are in the configuring_wld.pdf as <initial… but are <init… in the .xml. Small point but it confused me for a moment when I was searching the .pdf for tag info.
I noticed (2.01) that some of the tag names are in the configuring_wld.pdf as <initial.... but are <init.... in the .xml. Small point but it confused me for a moment when I was searching the .pdf for tag info.
Thanks - I missed that. I'll correct for next version.
Julian
