I have a Oregon WMR928N weather station and using Weather Display. I want to make a Solar / Sunshine hour sensor.
I understand that you can use a tempreture sensor a glass jar and some black paint.
Can anybody point me to a web page with “How to construct” information.
Many thanks
Regards Brian
but you can use a extra temperature sensor with the wmr918 as a solar sensor: place it in a glass jar, and paint the bottom black, so it heats up in the sunlight ...
then set the max temperature reading to say 18, and the low at 1 , the fine tune to 1 and 1...
then when the temp sensor in the jar is more than 18oc warmer than the station temperature, its 100 % sunshine...
and you fine tune it, and you also set the thresholds
[http://www.weather-watch.com/smf/index.php?topic=2187.0](http://www.weather-watch.com/smf/index.php?topic=2187.0)
1) You need to paint the bottom of the jar black. So, if the the glass jar is up-side-down, it would I assume be the lid painted black inside, so that the glass jar exposes the maximum sunlight into the jar.
[http://www.weather-watch.com/smf/index.php?topic=2419.0](http://www.weather-watch.com/smf/index.php?topic=2419.0)
hope this helps :D
Thanks for the replies
Before posting I bought the THC268 Thermo Sensor with Waterproof Probe.
I see that CaptDilli has used a complete unit THGR228 in a jar.
Vergil83 what type did you use?
Should the Jar not be upside down: with the lid painted black?
Regards Brain
...Before posting I bought the THC268 Thermo Sensor with Waterproof Probe. ...
The TCH268 should work fine. Brian adjusted WD to work with the THC268.
...Should the Jar not be upside down: with the lid painted black?...
Upside down or right side up should work. What ever makes you happy.
oh, I don't have one, I just remember this discussion from some time a long time ago :roll:
