I have a WS2550 with solar sensor.
I get the readings from my stations in Lux, then WD converts them into Radiation.
Example : 59100 Lux ==> 89.2w/m2
Than in ‘solar sensor setup’ screen, I checked the option : Update the solar value from this max reading for lat/long and time of day.
I also set the option: Set the weather icons from the solar data.
No the question is: where does the value ‘Maximum radiation for lat/date’ come from ??
It seems to be computed continiously but the value is very high compared to the actual radiation value (around 3 times too high).
The problem is that the percentage of the current reading compared to this Max value is always around 30% (mostly cloudy situation).
If I UNCHECK the option : Update the solar value from this max reading for lat/long and time of day, than the current reading is always 100% !
This means that in the first case I always have ‘Mostly cloudy’ conditions and in the second case I always have ‘Bright sunlight’ conditions.
Any help for this would be appreciated.
Oliver
