Solar sensor, leaf moisture
Hello Brian
This issue has been around for a while but I have been unable
to put much time into it due to other senor issues to be sure.
Now that I know my solar sensor drop outs are due to sensor overload,
have tested and confirmed a good Lens cap will fix that(still to put the Lens cap in place on the main weather sation solar sensor though).
Problem one
When the Leaf wetness sensor is connected the blocked in solar plot that is plotted on the main graph turns into a histagram looking graph disconnect Leaf wetness sensor and normal plotting returns to the solar blocked in plot.
Leaf wetness is connected at the moment
http://home.xtra.co.nz/hosts/zl2tsweather/
Problem two
There appears to be some interaction between the Leaf wetness and Soil moisture. The volts appear to interact with one another, Evan with one sensor connected the leaf wetness, soil moisture will still read only
after entering a ROM for soil moisture.
(I recall this being looked at some time ago, that got fixed, appears to have come back) Possibly this maybe linked to the Blocked in solar plot, problem one
Problem three
On restarting WD the Soil moisture ROM disappears from where the ROM is entered you need to renter this each time.
Regards John
from Windy Wellington
