Since V10.19 (all versions) there seems to be a problem with the solar setting first thing at sunrise
Although my solar temp sensor is showing heat, the solar reading is still 0% but then as it gets a bit warmer the solar reading jumps from 0 up to the correct reading of 13%.
i was working on stopping the solar % jump around sun set/rise for a non temperature sensor solar sensor,and i see a report that is still happening (although I did not realise I unfixed it), but that has stopped the compensation I had set in for your type of sensor from working (i.e I try to fix for one type and upset for another type)
i will revise it all tomorrow
I almost hate to post this. I’ts overcast drizzly and rainy here in NE PA USA. I have a Raw reading of 32.4, Current % reading 97%, Max radiation for Lat/Date 0, in the solar setup panel,
I have a similar problem. Always in the morning I get 0.5h of sun. But the weather was the whole day cloudy.
I tried to change daylight saving, but I moved only the spike.
I have the problem with the solar jump still. I get the problem when the computer changed from summertime to wintertime.
I use WD 10.19_o with WINXP and Davis Vantage Pro Active Plus.
I think I have the right time. You can see this in the screenshot below. I live in germany in the same time zone like Bern or Berlin. I ticked change automatically from summertime to wintertime.
I think I set longitude and latitude correct. See the next screenshot. Germany is in the east of London and on the northern hemisphere. The time for sunrise and sunset are the same as shown in my newspaper.
In the morning my Davis shows the first “current raw reading” at circa 7:52AM (See point 1 in the next screenshot). Sunrise was today at 7:39AM. If the “current raw reading” for example is 12W/m
in the solar setup, there is a tick for use daylight saving for the max reading from lat/long
you will now have to untick that
(or tick that if now daylight saving)
maybe i need to find some routine that automaticly knows if daylight saving or not
