Do you actually have a UV sensor?
Yes, I use the Mac version, but I had this running on my PC as well so I know it works. Double check your setup against the screen shots in the original thread at Use an OS THGR 810 temperature/humidity sensor as a global radiation sensor
I will get my PC laptop out and check my setup if you want to know what specific settings I used…let me know…
