Solar graph
I can
Presumably the solar readings are correct in WD?
Julian
I think so;-)
Is it this one you mean (see the attached file)?
Cheers
Magnus
Sorry :oops:
the data comes from 2 log files:
112004lg2.txt
112004vantagelog.txt
check the values there
They look like this:
day month year hour minute, Solar radation , UV, Daily ET, soil moist, soil temp
1 11 2004 0 1 0.00 0.0 0.0 0.0 255.000
1 11 2004 0 2 0.00 0.0 0.0 0.0 255.000
1 11 2004 0 3 0.00 0.0 0.0 0.0 255.000
1 11 2004 0 4 0.00 0.0 0.0 0.0 255.000
and
High soil Low soil High temp Low temp Snow Depth
0.0 0.0 10.8 0.7 0
0.0 0.0 0.6 0.6 0
0.0 0.0 8.6 -1.4 0
so you have ticked, in wd, in the solar setup, to plot as temp #4?
(so that then the solar data is in the clientrawextra.txt file)
That did the trick!
thats good (that is On now by default for new users)
