Solar graph question
Just installed 3.01 - excellent software :smiley:
A question re the 24 hr solar graph. I plot solar % rather than wm/2 in my WD. Have I missed something in the WD and/or WDL config to enable % or does WDL only graph the wm/2 values?
at the moment its only the solar wm/2 coming through in the data
how does that look?
also, you need to be using the latest version of wd to get the 30 day graph data to come through
(via the clientrawdaily.txt file)
actualy, it might be solar % coming through, but it will say wm/2 in wdl
It looks pretty good. It would be good to know whether or not it is % or wm/2 and then get the label in WDL correct.
looking at my code, it will be % if you have that ticked
and so julian will have to add a xml tag…
and so julian will have to add a xml tag...
Can you just add a 0 or 1 to the end of the clientrawextra array to match what was set in WD? Then I can make it automatic.
Julian
I note that the shape of the solar graph in WDL looks nothing like the WD one. Is this due to the compressed nature of the graph and fewer samples/plot points?
Also any chance of getting the the time as well as the data when you mouse over the graph?
Yes, there are only 20 samples across the 24 hour period.
The time does appear but only when it corresponds to a value on the x axis.
Julian
Ah hah - I see it now. Thanks Julian. :lol:
