Version 10.18d the snow detail.gif files has is saved with the right side cropped cutting off part of the numbers
alot of that is becuase of XP’s extra wide title bar
setting xp to use classic style fixes those issues
i use windows 2000, and so dont have these issues
That was easy enough to try out, Since WD is now running on its own computer… Switching to the Classic Windows style and restarting WD did fix the large screen dial output, for a while at least.
Attempting to use the Wind Only gauge screen however did not change. It was still cut off at the bottom.
Even worst than that, after you try the Wind Only gauge screen, and you try the full Gauge screen after that, you
find the full Gauge screen now looks just like the Wind Only screen and you never get the full page back unless you exit WD and restart it.
I tried this several times and it always did the same thing. After a while of turning it on and off, the bottom starts to creep up and you start loosing parts of the bottom dials. My guess is that a internal setting is getting stepped on that determines the size the window needs to be.
i cant duplicate here…its ok for me
at greater than 800x600
and having wd set to use large screen size
what screen size, etc, are you using?
WD 10.18d
WinXP Pro SP2
Screen Resolution is 1024x768
WD is set to use full screen if 800x600
I dont have any W2k boxes.
i will test on the kids xp pc…
anyway, a new 10.18d should be better for the snowdetail.gif image
sorry about the slow reply on this with the snow I have the program set to use full screen size if larger than 800 X 600 I’m running 1024 X 786 will try new 10.18d and see if there is a differance but I was already using 10.18d
