Yes it looks like all of the years are in one line.
John
new .zip update ready now
fixed
All is well at johnsnhweather. It works perfectly.
Thanks for great support.
John
John,
Glad its working.
I’m still confused by my graph:
http://cvweather.org/snowdetail.gif
Which is (pink) colored on the left side, what am I missing.
I have had zero snow for day, month, year and season.
make sure you do not have set to store current snow depth instead
under input daily weather, snow input
also have a look at your snow logfiles and check the snow totals
Hi Ed,
If you have had zero snow your graph is correct, That’s the way it looks until you get some snow. As soon as you get any snow the entire graph resets and displays correctly. I’m not sure why it looks that way. At the beginning of each month the report looks like yours until you record snow.
John
John,
Thanks for comments. No snow in forecast here for the next week.
I'm not sure why it looks that way.
its to do with the way the graphing component auto scales
Brian
Thanks for the explanation. I often wondered why it did the color fill-in below the zero line til there was snowfall.
Cheers
MikeyM
The snow history graph has stopped working in the latest build.
John
OK
same problem as before
the next update of WD will fix it again (permantely this time)
OK Thanks Brian all fixed.
John
