Slightly stumped
I’ve activated the sending of the clientraw.txt file and it is getting to the server. Took a while to figure that out :slight_smile:
I modified the html file so that it has the correct information about the config file and if I use that URL, I actually get the clientraw.txt file contents.
However… when I run the configuration, it gets stuck on configuring…
URL: http://www.tnet.com/weather/KAZMESA12/WD/wd-live.html
Not sure what I am missing…
Contents of the changed lines:
[code:1]
[/code:1]
[code:1]<EMBED src=“wdlv2_04.swf?http://www.tnet.com/weather/KAZMESA12/WD/wdlconfig.xml” … [/code:1]
I think it may be because you’ve got 2 directories which are uppercase - KAZMESA12/WD . Try changing them to lowercase. That’s something I’d been meaning to fix and forgotten about.
Julian
Is this something you might have fixed shortly? I’d rather not change the directory structure if possible though I could setup a temporary symbolic link to the same area using lowercase.
I just created symbolic links and it is working now…
Not 100% sure yet how I am going to do this. Might end up with weather.tnet.com or might even use a different domain.
Will purchase as soon as I know unless I can get the registration changed if I change the domain down the road.
No problem with changing the domain - just send me an email.
Julian
