where did you email to?
as I have not received it
email turned up
but password is incorrect
Have replied to your email.
Cheers
John
OK, got logged in OK
everything checks out on the WD end
files were uploading and were current in the WD webfiles folder
but I noticed you are using a fixed IP address for the ftp server in the WD setup
now, I deleted the clientraw.txt file on the actual server, in the public_html file
(using the built in ftp server in WD)
but that file was still visible at
http://www.mosgielweather.info/clientraw.txt
so that makes me think its a problem with your server, even if they tell you otherwise (very typical)
I tried changing the IP address to ftp.mosgielweather.info
instead
but that results in a password error
then I tried pinging www.mosgielweather.info (from here)
that returned an IP address of
64.37.52.52
which is different to the one you were using 67.23.226.159
but that results in a password error as well
you need to contact your ISP/FTP server provider to say the problem is on their end
Niko might be able to help here too…
Thanks Brian,
I really appreciate your time on this for me.
I will try and get my new host to get me changed over to him and forget the current one, sick of them.
Thanks again.
John
I’ll have to stick with Kenny Rogers here, “Know when to walk away, and know when to run”. I would run away from this host
LOL Niko. I am running as fast as I can. Have friend going to host it for me hopefully later today. Then I will be asking HostBig for a refund.
Edited: 9:37 am 6 June
All fixed Brian
Hi Brian
Got John WDL up and running on the new server. Had a few issues to get it right but the main thing he is on a much better host now.
I think I may have broken something and I will struggle to fix it so I think John may ask if you could kindly remote in and assist.
His WD page http://www.mosgielweather.info/Mosgiel%20Weather.htm is not updating now. It is set to update each hour but is failing to do so. Very sorry if I done something to stop it from going. If you change the htm filename for this page that is fine because it will be very easy for me to edit the index file on wdl to have the new name .htm page link changed.
Thanks Brian for your help and a big thank you to my friend Huggy, between us we spent a lot of time getting changed over to my new host and getting everything working again. If it wasn’t for Huggy, I probably would have given up and just gone offline. My old host keep telling me it was something in the software, we just proved them wrong. I’m going to ask for a refund from them, but not holding my breath.
Thanks again
John
good work in getting it updating on a new server
Thanks Brian. Great service, advice and help here, much appreciated. My old server might be cheap, but also useless it seems, as they kept blaming the software, WRONG.
Thanks again for the wonderful support.
John
