Since Update to 9.92 Temp/Bar
… Rain/Hum Graph in Main-Display are not renewed.
A Reset do not change the Graph.
Wind is working fine.
An Update to 9.92e brings equal results. ;-(
Best regards
Dieter
http://www.bottwartawetter.de
your web page url doesnt seem to wiork
what weather station type?
are you displaying 24 or 48 or 72 hour graph on the main screen?
Oups, sorry, the right URL is http://www.bottwartalwetter.de.
The Main screen is at http://www.dieter-geiger.de/bottwartalwetter_aktuelle_grafik.html
The weather station is a Heavyweather WS2300
The last Update of the last part of the graphs (Hum, Rain, Temp) ist bevore the Update from V9.92d to 9.92e.
The station is counting the rain and the temperature very well.
The other pages (like http://www.dieter-geiger.de/weather/wx.html) are up to date.
I have reset the graps and rebooted the system.
Best regards
Dieter
i think you need to add a barometer offset
i.e a minus
i.e your readings are too high
(and i have put a check in for that)
under setup,barometer offsets and rainfall
Thanks, after the change of the offset the graph is working fine. ?!?
The Barometer on the left side is working and shows the wright rate.
If i change the offset the indicate of the left side shows the wrong rate.
The graph of the left side shows always wrong rates.
Is the Barometer on the right side the absolutely pressure ant the graph on the right side the relative pressure?
How can i change this?
Best regards
Dieter
i have found the bug
it was a change i made that only affected the WS2310 station type
uploading a new verison now
(9.93)
note: you can also set the baro offset on the station too…
what is the barometer on your station
(but the barometer issue is another thing separate to the above introduced bug)
The Baro on the Station shows 1011.7 and WD shows (in the left side) 1011.7.
In the graph WD shows between 1033 and 1043hPa.
If i lift/lower Barometer-Line at the graph-setup nothing changes.
Thiss is the same if i use 9.92 or 9.93. ;-(
Best regards
Dieter
do you have any barometer offset set?
does this happen after a update from the history at start up
The Barometer offset is 0.
If i make a “graph setup” - “correct graph” - “barometer correction” and pess the “Correct”-Button the data at the graph in the right window seems to be o.k. for about 2 or 3 seconds. Then the data are shit again and i also cant correct (lift/lower) the barometer line.
You can see the wrong line at http://www.dieter-geiger.de/bottwartalwetter_aktuelle_grafik.html
Best regards
Dieter
email me your settings:
wdisplay.ini
from c:\windows or c:\winnt
and
wdisplayftp.ini
from the registry
see here for how:
http://www.weather-display.com/exportregistry.html
and your latest.inf file and month102003.inf from the datafiles folder
and I will try and replicate with my ws2310 station
after I take the kids to playcenter
(i.e in 4 hours from now)
o.k. the files are in your Mailbox an i will go to bed.
Have fun at the playcenter. :slight_smile:
Best regards
Dieter
the bug that created this problem is fixed in verison 9.93
note: you are using i see 24 hopur graph option for the main graph (see under graph history), changing to 12 hour shows respectible readings.
now, to fix the 24+ graphing since the bug was introduced, do this:
action, import log files, convert wd log files to graphs, then select the file 102003lg.txt then click on convert
that should do the trick
let me know
let me know
Now the results are good. :lol:
Thanks very much for the perfect and competent assistance. :!:
Best regards
Dieter
thanks for the thanks !
good its all ok again
All working well again with the graph history here too thanks! :smiley:
ricky
i have just discovered what is wrong the labjack solar plotting ricky
i will update that fix tomorrow ricky
thanks for putting up with me guys
(like when I fix something for one person but break it for someone else)
Thanks Brian :slight_smile:
sorry, can’t help laughing but… now the solar plot works but none of the extra sensors plot anymore! (all give that fixed high value reading that the solar used to)
If it’s a pain to get both working I’d prefer the sensors rather than the solar right now :slight_smile:
actually if you do get a chance to look at it can you get the extra sensors 1 to 6 to plot on lines 1 to 6 instead of 1, 3, 5 and allow say sensor number 8 to be used for solar, for some reason 7 and 8 just give 0 V if i try to use them for solar…
Anyway leave it until you’ve done with other more important things :slight_smile:
And thanks heaps for the help so far, I get very excited about expanding my setup here whenever a new possibility comes along :smiley:
Cheers
-ricky
it goes in odd numbers like that because the in between are for humidity…
actualy, i still have not got aropund to fixing the temperature offset bug…
anyway, i should have fixed it for you labjack readings ricky now
grab a new download (full download) in about 1 hour from now (to be sure to be sure)
Cheers Brian :slight_smile:
so where do those humidity values come from? couldn’t work that one out… :?
