Show Tags "snowrain"
I have a heated rain gauge, and use this “tags”
%snowrain%…rain measure by a heated rain gauge when temp below freezing times 10 to give estimated snow fall
to show “Snow today with”.
It works well all the time, there is only one small problem with it.
If it showed “Snow Rain” yesterday, and there has been no precipitation today.
If I then restart WD, will yesterday’s value up again, as today’s value?
It does not clear, until I manually change the value in wdiplay.ini before I start WD.
Can this be adjusted?
The same happens if you use this “tag” in the Windows version of WD.
Greetings
Bertil
OK, will fix for next update
build 69 there now
sexy build that one
