Setting up Server/Client WD
I’m trying to set up a server/client connection, on a lan. The client doesn’t update… I set server on the server (where the weather station is) and client on the client machine… Is there something I am missing?
And, as I read through the forum, and learned more about this Brian guy, I am amazed! What’s in that milk you’re makin’? What a great product!!
Bud Williamson
try using just the default IP address , for both the client and server
i.,e
231.31.31.31
and 333 for the port number
yes, I am a dairy farmer
I am standing here with my gumboots on and overalls on with the first row of cows miking
see
http://ps.gen.nz/~windy/
:slight_smile:
I started using the default IPs, but that wouldn’t communicate. Should I see the “Data Received” light blink green or something on the client side? I was able to get it to respond to a clientraw.txt file that I ftp’d to a site.
I do have a seperate ip set up on the server machine - does that mean anything? (I tried setting that number, but that didn’t work either)
Enjoyed your site…
Bud
You need to get a Wifi connected tablet PC so that you can be standing in the shed with the cows and still coding :robot: Just think of all the extra coding time if you didn’t have to walk from the cow-shed to the PC :wink:
very funny.
the cows will be dry in a few weeks…
client/server:
yes the data received light shiould flash
export and email me your wdisplayftp.ini file from the registry…
see
http://www.weather-display.com/exportregistry.html
from both pc;s
and also try the old restart wd trick on both pcs
You mean the shed isn’t already wired and computerized??!!
Brian,
OK, I’ll get those files gathered & sent… I assume you are done milking? Is it play time now?
Appreciate the support,
Bud
yes, computerised sheds and even robot milkers you can get
i think of myslf as a robot milker
LOL
I can see it now…
An old 386, the wife’s Hoover, a bunch of wires 'n stuff and Brian in deep thought…
Hmmm, where’s the manual, was it “1” to blow, and “0” to suck, or the other way around???
:stuck_out_tongue:
i have him sorted by the sounds of it…he had ticked data from over the internet…
Actually, I’m back to receiving from the internet. It wouldn’t work the other way, although I thought I did have it. I’ll play with it today, after cold reboots on both machines…
oh…
try also the free client viewer for the non internet setting, and see if you can get that working…
It doesn’t seem to work on either WD or client viewer on the network, only via internet. That works for me…
One more question on Client/Server; Does the Solar/UV data get sent (via clientraw.txt)?
it should work, and does for 99% of cases, but sometimes there are things that stop it…and i am no expert
a firewall is one thing…
solar is in the clientraw.txt, and the client viewer uses it
and wd as a client will too…
but i will add option to actualy use, next week…(i am away for the weekend )
