Setting for WM11
Brian…I just discovered what is happening regarding the settings. When I set my Weather station configuation to WM11 Full, clik okay, close the program, re-start, the setting does not hold …it reverts back to the other WM11 setting, not full…Joe
make sure you click on the needed baud rate as well
that will set it to the correct weather station type (i.e the needed baud rate for the davis WMII full
Brian, I have been using 2400 …is that correct…also my operating system is windows XP…thanks Joe
just done some testing here
try this:
untick the baud rate from the standard wmii baud rate setting first
then tick the baud rate needed for the WMII full (untick then retick it if its already ticked)
then restart wd
Okay Brian…I changed the baud rate from 2400 on the WM11 Full to 1200 and it worked! Is 1200 correct? Thanks…sorry for the nagging…Joe
you need to set the baud rate to what the console is set to.////
what is the console set to?
if you are getting data, then that must be the correct baud rate
