Sensor 1 temp (solar) and various plots
Sensor 1 on my WMR928N is the solar sensor. If I look at the value displayed/plotted in different places it show different values. For example,
  1. 928 console : 31.4degC
  2. WD View | Extra Sensor 1 : 31.4degC
  3. Extra sensor real time graph plot : 19.x degC
  4. Extra sensor real time graph numeric value : 31.4degC
  5. Solar Graph plot : 41.x degC
  6. Solar Graph numeric value : 41.4degC
4 & 6 are the values displayed when the time line is placed at the end of the plot line.
Is the difference between these responsible for the alternate values displayed on the solar % bar on the main WD display?
WMR968 Solar Sensor in a Jar (Extra Sensor #3). WD v9.72e
At this time, My
check you dont have a solar sensor temperautre offset in the solar sensor setup chris…
strange you have a good solar plot captdilli, but you are geting the bouncing number,.,.
i have found the problem
it will occur when you have update icon from solar ticked
and i was missing 1 line of code, to compare the solar temperature to the station temperature difference
uploading a new 9.73 version now that should fix this
try a new 9.73 now…
lots of rain here last 36 hours
now 60mm
try a new 9.73 now....
now 60mm
Thank you.
9.73 looks good at first glance. I did not have update icon from solar ticked. I do have ‘Show apperent solar temp’ ticked.
Do you have a boat or raft? :lol:
we did get 25mm (1 inch) in 30 minutes at one stage :slight_smile:
