I would like to email a monthly NOAA report. What do I have to do to send only the monthly report to specific recipiants?
I haven’t tried this myself yet, but it looks like what you are looking for.
Under: view > averages/extremes - NOAA style reports
At the bottom of the page, turn on the second switch that says “email the reports to the weather report email list at the end of the month”
Then just under that, you can tick the box that says “use these email addresses instead”, and enter your addresses there.
Should work I would think. I am using the daily NOAA report emails (from the same screen) without having anything turned on under [FTP > weather report email] and it works fine.
Thanks. I’ll give that a try when I get home this evening. I’ll let you know how it goes.
Paul
I’ve tried everything you suggested with no success. It appears as if most of the options are for emailing DAILY NOAA reports. I would like to generate the MONTHLY report and email it whenever it is generated. Any help would be appreciated. Thanks.
Paul
I think it will email the report, at the end of the month. Set up the email in the FTP/Internet tab under control panel. Then setup the NOAA report under view and NOAA reports. I set mine for daily and monthly reports to be emailed. Daily is working, but the monthly won’t send anything until the end of the month most likely.
You can customize the noaa reports using the noaahtm0.txt, noaahtm2.txt files in the webfiles directory.
