Selecting CWOP from Control Panel Publication Halts user interaction WD GUI
When I open the control panel and select the CWOP icon from the publication area WD stops responding to user control. It appears the program is running but I can’t open CWOP or select and use any feature of the WD program or exit. Thinking perhaps the latest release would solve this I upgraded to 10/37S v19 but the problem remains - thoughts?
this setup screen will be opening off screen will be the problem
(clue: hit the return key on the key board to see if that closes it)
try resetting this setting
[Main cwop setup]
last cwop setup top=
last cwop setup left=
in the wdisplay.ini settings file when WD is not running
Return did the job - many thanks for the assist.
you will still need to reset the above settings
