Screens not updating?
Hi All
Using WD 10.20o as stationless. I am downloading METAR data for my local area.
When I save and exit, I notice that my Lat/Long is not being saved and that the wind speed dials (on restart) refuse to show current wind speed and direction. I have checked and the METAR is sending all the information. I have not changed any of my settings since the upgrade. Can anyone shed a light on this?
I reset everything to update every 10 mins and uploaded to my web site. My Lat/Long is wrong (and I do know how to set it - thanks guys!), and some of the METAR info is not being displayed ie Wind Speed (currently 20MPH WD shows 0 although direction is correct.
Sorted the problem out - reverted to 10.20m version and all is well again.
if you could get me your settings, i will see what is up
go:
action, back up registry entry now
then email me the files wdisplay.ini and wdisplayftp.reg from the sub folder databackup that is created
I have just started 1.20o and the wind from the metar is not on the dial also. Been ok up to now.
i will do some testing and investigating
is this with the setting to use the metar to update wd’s data?
Yep. Only the wind speed does not work wind direction and everything else is fine.
[My new vantage pro is taking the long route to get here??]
Cheers
found it
happened when i set the length of a string, to reduce memoru use, but I had set the length to small
uploading 10.20q now to fix this
Bingo :smiley:
Sorry, but I was a little quick with installing the older version. I will download the 10.20o and have a go with that.
10.20q fixes this introduced bug :slight_smile:
10.20q fixed all the problems that I have reported. I’m happier than a really happy person. Now, all I need is the January Sales and buy a proper weather station…!
