This is an svg (Scalable Vector Graphic) web page that dynamically updates using my clientraw.txt file. Comments, Suggestions are welcome and encouraged.
http://RuppWorld.com/svg/svg.htm
Its requires an SVG plugin available here (near the bottom of the page):
http://www.adobe.com/svg/viewer/install/main.html
You should be able to use your clientraw.txt file (if your browser is set up correctly) but if you do not have one use mine currently at:
http://12.219.152.208:8000/weatherpage/clientraw.txt
