Resetting all time and monthly records
I have gone though the actions menu and reset the values but for some reason my max/min temps day and night do not reset. They reflect a very incorrect number. In fact they appear backwards. The min nightly temp is 122 degrees and the warmest day temp is -58 degrees.
Like I said I have reset using the option in the action menu. I also went into the wdisplay/webfiles and deleted the alltimerecord.gif and alltimerecordmonth.gif. All it did was recreate them with the same values.
Please help me
http://mysite.verizon.net/res0zhcx/stevesweather.html
I really like the program. My only current problem is the all time records problem. I would like to purchase the program but I would like this problem worked out first. thanks
Normally, that “disappears” after a “actual” temp is recorded for the entire night and day time. What you can do, is just go under all time records, then set values, then set new values for those two “records”. Then the -58 and 122 is not present. The values should update on there own, however. Try letting the program run for a couple days and it “should” get “real values”. I just reset my all time night temp, and will see if it updates for me.
~Chris~
thanks for the reply. i will try that.
yes, the values start off at readings that will obvously get beaten
but they dont actualy get set until you reach 6pm or 6am, as they are the average of the temperatures recorded for that 12 hour period, and the value is applied /compared at those times, for those particular all time record values…
so, yes, after 24 hours running, it should all set/work correct
thanks
:slight_smile: :wink:
