Request for new tags
Hi!
In my tagslist.txt I’ve found the following tags:
%recorddaysnorain%…All time Record days with no rain
%recorddaysnorainday%…Day of month record days with no rain
%recorddaysnorainmonth%…Month of month record days with no rain
%recorddaysnorainyear%…year of month record days with no rain
Is it possible to add the “opposite” tags?
%recorddaysrain%…All time Record days with rain
%recorddaysrainday%…Day of month record days with rain
%recorddaysrainmonth%…Month of month record days with rain
%recorddaysrainyear%…year of month record days with rain
Also I would like to see these tags:
%consecdayswithnorain%…Current consecutive days with no rain (this should reset to zero when one day with rain)
%consecdayswithrain%…Current consecutive days with rain (this should reset to zero when one day with no rain)
Regards: Geir Vigesdal
www.vigesdal.net/weather/weather.html
i will see what i can do about the new tags
note that these tags exist already:
%dayswithnorain%
Hi Brian!
Yes I’ve found the tags you are mentioning.
But I’m a little puzzled by the way they behave.
On my page I’m currently using these custom tags:
%consecdayswithrain%…Consecutive days with rain for the month
%dayswithnorain%…Consecutive days with no rain
I assumed that the %consecdayswithrain% should reset (zero) when it starts to rain again.
But it seems that it needs 4-5 days with no rain to reset.
After 3 days with no rain, and than rain starts again, this tag continues (adding up to the previous period with rain).
It shouldn’t be like this, should it?
The other tag, %dayswithnorain%, resets after the first day with rain.
Is there something wrong with this tag, or am I doing something wrong in my WD setup?
Regards Geir Vigesdal
what hour is your daily reset hour set to in wd?
Hi!
My daily reset for rain is 06:00 UTC (08:00 local)
Temperature and wind resets at 18:00 UTC (20:00 local)
These are the same times as the Norwegian Meteorological Institute uses.
Ref. www.met.no
Geir Vigesdal
i have added all time record days with rain now (and custom tags) to a new .zip update, build 15, ready now to download
(and you can set the values too, under action, enter my own all time records, 2nd setup page)
Thank you very, very much.
Regards, Geir Vigesdal
i fixed a bug with this not being saved or reset at the month/year change, so download a new .zip update
