My Server Disk crashed, however had backups of PWS…(WeatherFlow/Tempest)
I restored directories under IIS and double checked PHP permissions.
Still having some errors…see attached JPG screen shot.
Q.) What to fix, where? directory files??
http://internetvail.com/SunriseDavis/startHere.php
check 2.2 : CURL support: result = ERROR 2.2 CURL support is not supported, FATAL
check 2.4 : GD support: result = ERROR 2.4 GD support is not installed, WARNING
check 3.3 : file_put_contents: result = ERROR 3.3 file_put_contents is not supported
http://internetvail.com/SunriseDavis/PWS_load_files.php?test
NO DATA will be loaded - unable to open file to save data into:
C:\inetpub\wwwroot\internetvail\SunriseDavis/jsondata/wlcomv2API.jsonrnm,
check permissions of file and folder.
The data-folders are not writable even for the scripts themselves. Check these folders first
_my_settings chartsmydata chartswudata jsondata wudata nws-alerts\alertlog nws-alerts\cache
Error: nws-alerts.php requires curl to operate.
curl is not functional on this PHP 8.2.5 installation.
Status of needed built-in PHP functions:
function simplexml_load_file is available.
function curl_init is NOT AVAILABLE.
function curl_setopt is NOT AVAILABLE.
function curl_exec is NOT AVAILABLE.
function curl_error is NOT AVAILABLE.
function curl_close is NOT AVAILABLE.
