records
Hi from France
I’ve bought WDL 2.03 and the “records” button doesn’t work… It loads, but nothing appends…
Did I miss something ?? :oops:
Regards
what is the url ?
also, i would upgrade to the latest 2.05 of wdl
and we can go from there
You’ve got a cross domain security problem anyway. In the html page you’ve specified -
VALUE=“wdlv2_03.swf?http://plebraud-baobab.org/wdlconfig.xml
but the page always loads as http://www.plebraud-baobab.org. Try changing the 2 lines in the html page so the config says -
VALUE=“wdlv2_03.swf?http://www.plebraud-baobab.org/wdlconfig.xml” and see if that helps.
Julian
I’ll try this, I tell you if it works like that
So, I’ve tried, but now it says “error loading records”
How can I update to 2.05, I need to pay the licence again ??
Ah yes you’re running 2.03 - I think the problem is because the clientrawextra file is now too big for what was allowed and I had to change the array size. Definitely try 2.05 - it’s a download from the Weather Display site and all upgrades are free.
Julian
OK, I’ve downloaded 2.05 version, and updated my page, so now, I can have records…
Thanks for this
Still one little question
Here is an extract of my wdlconfig.xml
60
3
french
dd/mm/yyyy
1
0
C
<initWindUnits>kph
mm
hPa
m
humidex
1</showBeaufort
As you can see I’ve setted “kph” to have windspeed in this unit at the opening of the Flash page… But it doesn’t work and “mph” is setted and I need to change it each time
Here is the page http://www.plebraud-baobab.org/LIVE.html
Perharps, I’ve missed sometihing :roll:
Thanks for resolving my “records” problem :smiley:
maybe try kmh as a test
(might be a language setting)
I think it’s a bug with that version - try entering km/h which should do it.
Julian
I’ll try as soon as possible, I’m not at home, I’m at job sometimes… :lol:
Running v2.05 and intermittantly I have a problem loading records. Brian mentioned in Chatter that v2.05 fixes this problem and I wanted to let you know that I still see it.
http://weather.dcrooks.net/indexlive.html
Forcing a reload of the page usually fixes the record problem. Seems more pronounced right before or after midnight.
I’ve changed the way the loading works in v3 so let me know if it’s not any better when I release it.
Julian
