Like many, I’ve had a few bad temperature measurements (wd-2310). I’ve been able to edit the log files to correct the values, however the bad data corrupted the monthly, yearly and alltime records. Reseting the records doesn’t appear to reset the value to the actual low in the log file, it just uses the current temperature. If I view avg/extremes and select the day of the bad data it shows the corupted min temp for that day, if I then click correct the data, it show the new values which I updated. Why is it still wrong in the reports/records and is it possible to update it?
Gary
