The realtimegraph.gif keeps chopping off the right side. I have set the width to 100 percent, placed it inside and outside a table but still keeps happening. - Suggestions? Running WD 10.13k XP at screen resolution of 800. See website: http://pweb.jps.net/~tomcombs/weather/wx.html
the problem is running windows at screen resolution of only 800x600
(either try running it higher, or i will reduce the width of that screen in the program to fix this problem)
also, remove the width and height commands in the <img src= html code in your web page to let the images show better
try a new 10.13m , ready now
it should be better
Brian thanks for info. FYI. Version 10.13n did make it better. I noted when I downloaded the new version and viewed realtime.gif in my gif viewer it was excellent. However for whatever reason after WD did a download the picture was slightly cropped again - not nearly as bad as before but still somewhat cropped. I donβt know if it is something on my end ( most likely) or something in the program.
I can live with it as is. I am giving you this feedback in case you get more inquires with the same issues.
Thanks for the help as always.
