Real time graph: temp and dewpoint wrong
Brian,
on the real time graph I get values of about 2600 Celsius for temp and dewpoint!
This is for a longer time so.
Peter
What version of WD are you running? Also have you tried clearing the real time graphs to see if this clears up the problem. There is a new option to automatically clear the records for the real time graphs every 3 days and this has fixed most of the problems I see with them.
I run 9.45B and I do not have ticked that, because it was not clear to me what is that option for.
I try now and see.
Peter
same problem again!
Temperture and dew ponit at about 2600 Celsius
Peter
you will need to set the low graph threshold to lower than -20 oC if your readings are going less than that
also, i will make a move down or up arrow too , so you can see those low readings (when it goes below the low threshold reading, it then goes over scale, but changing the scale will fix it)
sorry , i missed seeing this post!
