Real time graph - stopped functioning
Ver. 10_17z The plotting for the realitime graph has stopped. I suppose that I must have unclicked a button somewhere, but I cannot locate the error. Help please.
are you sure it has
it does reset once the total records gets to 5000 (default) , or the number you have set there.
(note, I used to have it where it tried to chop off data,but the graphing component has a bug, and the data file would end up being HUGE and cause all sorts of problems, so the only solution is to have it reset, like it is now
I will check it again when I go up to Truckee, but I don’t think that is the problem. As you can see at the website:
www.weather.snowshoetruckee.com it is still printing blanks. More to follow on Nov-11-2004 Thanks for prompt reply.
Tom
Your entire webpage has not updated since this morning…
LAST READING AT TIME: 04:20 AM DATE: DATE: November 02 2004,Time of next update: 6:00 AM
Just took a look at it…
i think the clue with the real time graph, is where it says, total records to date, is zero
so it might be the resetting of the real time graph (this needs to be done at regular intervals ( you can make it longer).
