I managed to see the problem occur here
(i.e where the login fails and then it just repeats to logout every 5 minutes)
after I set the restart to every 5 minutes
try another update download and I will run here as well
Have the same issue as mentioned in this topic I think. Nothing changed in WD but in the last weeks every day it occurs at night.
This is the log from the real time clientraw ftp last night:
Real time Clientraw FTP, vers 9.4
***Time/date***:3:40:26 23-8-2017
Logging onto SFTP server....sftp.leudalweer.nl
OK
OK
Sending local version: "SSH-2.0-IP*Works! SSH Client v9.0".
Read remote version string: "SSH-2.0-SshReverseProxy".
Beginning key exchange
Preparing algorithm negotiation.
Sending local enabled algorithm list.
Reading remote enabled algorithm list.
Selected key exchange algorithm: "diffie-hellman-group14-sha1".
Selected server host key algorithm: "ssh-rsa".
Selected client encryption algorithm: "aes256-ctr".
Selected server encryption algorithm: "aes256-ctr".
Selected client MAC algorithm: "hmac-sha1".
Selected server MAC algorithm: "hmac-sha1".
Selected client compression algorithm: "none".
Selected server compression algorithm: "none".
Algorithm negotiation complete.
Sending Diffie-Hellman key exchange initialization request.
Verifying server's Diffie-Hellman key exchange response.
Diffie-Hellman key exchange complete. Calculating key sets.
Sending new key packet to server. Setting client keys.
Received new key packet from server. Setting server keys.
Key exchange complete.
Requesting service "ssh-userauth".
Service request "ssh-userauth" accepted.
Authenticating user for service "ssh-connection".
Requesting user's authentication mechanism list from SSH host.
Attempting password authentication.
Password authentication succeeded.
Successfully authenticated user for service "ssh-connection".
Attempting to open "session" channel [0].
Successfully opened "session" channel [0].
Attempting to start service "sftp subsystem" on channel [0].
Successfully started service "sftp subsystem" on channel [0].
Negotiated SFTP protocol draft version: 3
Changing to remote directory /www/
SFTP Uploading C:\wdisplay\webfiles\clientraw.txttemp - >clientraw.txttemp
C:\wdisplay\webfiles\clientraw.txttemp uploaded ok 3:40:28
Renaming clientraw.txttemp -> clientraw.txt
1103: File rename failed [11]: File already exists.
SFTP Uploading C:\wdisplay\webfiles\clientrawextra.txttemp - >clientrawextra.txt
C:\wdisplay\webfiles\clientrawextra.txttemp uploaded ok 3:40:28
SFTP Uploading C:\wdisplay\webfiles\clientrawhour.txttemp - >clientrawhour.txt
C:\wdisplay\webfiles\clientrawhour.txttemp uploaded ok 3:40:28
SFTP Uploading C:\wdisplay\webfiles\clientrawdaily.txttemp - >clientrawdaily.txt
C:\wdisplay\webfiles\clientrawdaily.txttemp uploaded ok 3:40:28
C:\wdisplay\webfiles\clientraw.txttemp uploaded ok 3:40:33
C:\wdisplay\webfiles\clientrawextra.txttemp uploaded ok 3:40:33
C:\wdisplay\webfiles\clientrawhour.txttemp uploaded ok 3:40:33
C:\wdisplay\webfiles\clientrawdaily.txttemp uploaded ok 3:40:33
SFTP Uploading C:\wdisplay\webfiles\customclientraw.txttemp - >customclientraw.txt
C:\wdisplay\webfiles\customclientraw.txttemp uploaded ok 3:40:33
and so on every 5 seconds, further:
C:\wdisplay\webfiles\customclientraw.txttemp uploaded ok 4:10:33
C:\wdisplay\webfiles\clientraw.txttemp uploaded ok 4:10:38
C:\wdisplay\webfiles\customclientraw.txttemp uploaded ok 4:10:38
C:\wdisplay\webfiles\clientraw.txttemp uploaded ok 4:10:43
C:\wdisplay\webfiles\customclientraw.txttemp uploaded ok 4:10:43
C:\wdisplay\webfiles\clientraw.txttemp uploaded ok 4:10:48
C:\wdisplay\webfiles\customclientraw.txttemp uploaded ok 4:10:48
Logging off from server 4:10:53
OK
Doing abort procedure/program close...
OK
OK
Logging off from server 4:41:18
OK
Logging off from server 5:11:43
Logging off from server 5:42:08
Logging off from server 6:12:34
Logging off from server 6:42:59
… Then nothing more happens.
After button reset:
OK
***Time/date***:7:04:42 23-8-2017
143: Busy performing current action.
No further action!
After button stop:
No further action!
Close with cross don’t work.
Close WD save and exit.
RT CR FTP won’t closed and I must reboot the computer and also WD than RT CR FTP works for about one day.
I will try realtime clientraw ftp version 9.8 and let you now if it works for me.
Thanks for the update
I too had the same issue where the clientraw.txt would stop operating after exactly 24 hours. I am NOT running sftp, but rather just passive uploads to my web server. There isn’t any error messages and in fact, the icon stays in the taskbar, but does not upload and no upload arrow. If I just mouse over the icon in the taskbar, the icon then goes away. I can restart the clientraw uploads via the real time client ftp menu without having to reboot the program and it will run for another 24 hours.
I have downloaded 9.8 and will give that a shot and let you know how it works out. FYI, this is happening on two separate weather station computers and as I stated the stoppage of the clientraw upload program happens almost exactly every 24 hours.
@stantomj
that sounds like a different issue
(where the program has actually crashed)
do you have to restart instead of re login? try setting that
but also does the problem occur at a certain time?
Yes, I have to restart rather than re log in and it seems to happen between 6am-7am EDT. I usually catch it when I come to the work computer at 6am and reset it them so that is why I mentioned the 24 hours… I then look on my website and see the uploads stopped occurring around 6-7am.
It did not start until the latest changes in the Clientrawftp program earlier this week.
Mike
Well, after installing 9.8, the clientraw uploads have been running nicely well past 24 hours on both computers. I don’t know what the problem could have been, but seems to have fixed itself with the 9.8 version. Thank you for listening…
