Real time and solar graphs not working
Hi Brian
First let me thank you for putting the lighting notice on the WD.
I wrote on Sat Oct 4th about the solar graph not updating now that I look closer the real time graphs are not working as well.
There is an error message when the program starts could that be contributing to the problem?
This started when I updated to a new version. See the error listing below:
ERROR: Access violation at address 005A39CA in module ‘WeatherD.exe’. Read address 000000000 at time/date 4:56:38 PM 10/12/2003
Thanks for your help.
Failed to mention I am running Xp. Also, each time I restart WD I have to reset the type of weather station and the 1 wire set-up.
I would like to get this working again soon. The graph issue has been going on over a week.
have you taken out a web cam, or un set weather talking, or similar?
the start up error is causing the problems
try resetting the web cam settings or the weather voice settings
then restart wd
also, i have made some improvements to the whole solar sun shine procedure with a new 9.94
I had removed a web cam. Turned all items off but a residual picture remained. I cleared the picture by resetting all the parameters including the upload times. This has cleared the error. The solar graph under extra sensor graph is working again.
Will the dates return as well?
Best Regards,
Best Regards,
