Rather high barometer has been reported
All of a suddon all of my graphs have been thrown into chaos because of interference more than likly to the data logger. Its reported that the barometer has been up to 2009, temp has been 50c and humididy dropped to a low 5%. This has not been the case when the Barameter has been about 1019, Temp 13.2c and the Humidity around 70%.
Now all the graphs have gone out of wack because the maximums have been pushed right up to the highest (2009).
I have tried to fix it using the graph corrections but it has achieved absolutly nothing. Is there any other way that I can fix it?
oh, sounds like i need to put in place some data quality checking with the ws2500 data for when this happens…
one way might be to edit the log file, 62004lg.txt, to remove the or edit the data, then use the convert wd log files to graphs, under action…try that maybe
Ok I tried doing that but it didn’t work. I found the text file and editied out the errors and tried to put the graphs in the program. The strange thing is that It flat lined all the graphs in the program, yet the web graphs look fine however it never actually fixed the problem with the barometer and temps being all that way out of wack though which is rather strange. If you want me to send you the logs, please let me know.
hi oh, sounds like i need to put in place some data quality checking with the ws2500 data for when this happens...
Brian, maybe it's a dumb question but why not have global data integrity checking regardless of the weather station type? I don't know how hard it would be to come up with rules for the max rate of change of all the parameters, or if you were feeling creative make it user selectable.
actualy, i do have that, but for the ws2500 and ws2010 stations, it by passes that as the data goes direct to the minute records
trucker, zip and email me your log file, 62004lg.txt, and i will check it out
thanks
