Raspberry Pi with data logger
I have downloaded and installed the Rasp Pi image.
I have a Davis Vantage Vue with an IP data logger. I have tried all sorts of config.txt options but can’t seem to get it to find the data logger. The IP address is correct (can connect to the logger by ip). The port is 22222 when I run the full weatherdisplay console on another pc.
Can someone tell me what setting should be set in the config for an IP logger? leave USB/serial details blank? Select Davis IP Logger as the type? I’ve been trying everything but not the right combo
thanks
