Rainfall lasthour updating incorrectly on XP Client system
Win98 Server data (at startup)
Last hour 0.000in
Today 0.010
Yesterday 0.012
Month to date 0.180
Year to date 65.752
WinXP Client data (at startup)
Last hour 0.012
Today 0.012
Yesterday 0.012
Month to date 0.181
Year to date 65.752
Last hour data on the WinXP updates every minute at :00 with an increase of 0.012 added to it…
After 10 minutes Last hour data was 0.120, one minute later 0.132
(It is not raining so the server data is not changing.)
I rebooted both systems with same results…
Then copied all logfiles from the Win98 system to th WinXP system to make sure. Rebooted both systems… Same problem…
WinXP Client data (in the time it took to type this) (data now)
Last hour 0.480
Today 0.012
Yesterday 0.012
Month to date 0.181
Year to date 65.752
Forgot to mention:
Data from a Win98 client system 2 feet away does not do this.
Win98 Client data (at startup)
Last hour 0.000
Today 0.012
Yesterday 0.012
Month to date 0.181
Year to date 65.752
From XP graphing post:
Still trying to get the main graph to graph.
Searched all my computers for the oldest version of WDisplay I could find.
Found V9.65b dated 15Mar03. Installed it and the graphing is back. Ran for one hour. Then rebooted (complete shutdown) the XP system and restarted. The graphing is still going on. I will keep this running for another hour or so then will reinstall V9.94 to see if it stops graphing.
The Rainfall in Last hour problem (see post related to this) has changed its M.O. It is now not updating every minute at the :00 by adding the 0.012" but displays at reboot 0.031"… (again it is not raining) So I think that is just in a data logfile someplace… I will refresh my logfiles from the Win98 server later after I see if V9.94 continues to cause graphing problems. Just do not want to add another variable to this troubleshooting process.
the not graphing error, which is now resolved, has meant the rain last hour was not working correct
so it should all come correct now
note: you can copy the datafiles and logfiles from the server to the client version to get you up to date
Thanks for the fix. Working with the latest 9.94…
