Rainfall last 24 Hours reports strange
Hello
Please explain to me.
I am runing FreshWDL - Version: 1.1.8.12
When I look at my Rainfall last 31 days it reports 24.1 mm of rain yesterday
But…
Klicking on grafs and then Rain Fall last 24 Hours it reports 49.8
Why ?
Check the values in WD and in the clientraw files to see whether it’s a problem with the base data in WD, or a problem where WD is incorrectly transcribing the base data into the clientraw files. If those are both ok then it would be a FreshWDL problem.
Hey ! Plenty thx for replay
Here is my clientraw
But what should i look for
I can not find 24.1 or 49.8
12345 3.0 3.9 242 14.7 92 1004.4 2.5 41.6 465.5 0.00 0.13 23.9 48 100.0 5 0.0 0 0 24.4 20.6 -1.0 -1.0 -1.0 -100.0 -100.0 -100 -100 -100 09 09 59 XXXXXX-09:09:59 0 22 27 6 0.00 0.00 100 100 100 100 100 14.7 17.8 14.7 13.8 5 Overcast_and_gloomy/Dry 0.1 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 9.0 13.4 530.1 6/27/2023 17.8 16.7 14.7 13.8 1.0 3 3 2 2 3 2 3 3 2 4 14.4 14.4 14.4 14.3 14.4 14.5 14.5 14.5 14.7 14.7 2.5 2.5 2.5 2.5 2.5 2.5 2.5 2.5 2.5 2.5 14.7 13.8 14.7 6.8 0 — — 233 0 0 -100.0 -100.0 -100 -100 -100 -100 -100 157.6 25.2 23.9 17.6 1005.5 1003.7 8 08:34 06:41 17.8 13.5 14.2 13.0 6 2023 -8.4 1 -1 1 258 266 195 243 254 288 245 272 299 222 0.0 255.0 3.3 14.0 57.01667 -14.00000 0.0 99 91 0.0 06:43 0.0 0.0 0.0 0.0 0.0 0.0 33.6 09:02 06:43 240 !!C10.37S144!!
There are multiple clientraw files each with different content, e.g. clientrawextra.txt. Use something like Saratoga-Weather.org - Weather-Display clientraw*.txt parser to look at all your files in a nice readable format.
That was new to me…
When I run it via the parser I then get the following value
Link To clientraw.txt via parser
Rainfall “yesterday” means the rain that fell between 00:00 and 24:00 yesterday: WD usually resets the rain at midnight.
Rainfall “last 24 hours” means the rain that fell in the last 24 hours. It will only agree with yesterday’s rain if you look at it just after midnight.
I just think there is something wrong here.
Look at this
Rain Fall 24 hours
and
Rain fall 31 days
can someone explain to me
Please tell us the url for your FreshWDL page, or tell us what it says for “Daily Rainfall” - the rain today.
https://www.schultze.nu/weather/index.html
Ah. . . I see rain last 24 hours should only be about 27 mm.
I think your clientrawextra.txt file is corrupt, see lines 41-60 and 570-3. Try restarting Weather Display and see if it is corrected.
Reboot did not help.
I run WD 10.37S144 is that an issue?
And I have no UV in the grafs
In Weather Display view
Here Is what I see in the view.
Here I get the Value 24.4 for yesterday
Or solar. . . I do this quite often and I’ve never had a problem. Did you wait for all WD processes (like FTP) to finish before you restarted?
I don’t think so, I run build 10.37S145
I don’t know what else to suggest.
I see rain last 24 hours is OK now, but I have no idea what happened to UV and solar.
Have you contacted Brian, the author of WD?
