The rainfall in my area is often a topic of conversation since we’ve had over 31" of rain so far this year.
Is there an easy way to put the raindetail.gif on the main (front) web page? I even looked in the custom web page setup but didn’t see it there.
I guess I could add that image to my dadhtm3 file, but thought I might be missing something easier.
Thanks!
Edit:
Also, if you would look at this image…the top bar graph on the raindetail.gif…the figures at the top of the graph are way high compared to the lower graph.
The rainfall in my area is often a topic of conversation since we've had over 31" of rain so far this year.
Is there an easy way to put the raindetail.gif on the main (front) web page? I even looked in the custom web page setup but didn't see it there.
Thanks!
Edit:
yes if you are using WD’s auto generated page then you could add the image URL into datahtm3. And yes if you know HTML you could look at using a custom webpage(s) to display data and images the way you want them to (this is what I use) - the custom page overrides the auto generated page.
On raindetail.gif it seems the high figures above the graph are in mm and the graph below is in inches.
I added “raindetail.gif” to my datahtm2 file.
It shows fine on my page, but is not updated (still shows the older version with mm and not up to date). Will it update itself at a certain time? I looked around for a while and can’t find how or where to update it myself.
After I added the raindetail.gif…
After WD did its next upload - my raindetail.gif that I put in datahrt2 was gone. Should I check “let me manage the datahtm2 file” so it will stay there? Are there any other consequences of checking that box?
I guess it really is time for me to start using the custom pages!
it will stay on that file
(and you can also add things to datahtm0.txt and they will stay as well)
thanks go to picolio for that icon
(i iike it to)
I might see if i can find some other better icons to replace some of the other ones (see them all under input daily weather)
