Rain totals is not updating [RESOLVED]
It seems that I have lost an automatic update of the rain totals (monthly/Yearly). It counts every day it rains but dont add anything to month and year.
If I go in to WD and look at the Detailed Rainchart, there is totals until june where I have corrected them.
My websites is:
http://www.ved-kirken.dk/Vejr/
http://www.ved-kirken.dk/Himmelev/wx.html.
I have been reading lots of post about this problem but any of them have solved my problem.
I have just been looking at weather underground and there it seems to be ok.
http://www.wunderground.com/weatherstation/WXDailyHistory.asp?ID=IROSKILD3&day=1&year=2011&month=8&graphspan=year
regards
John
Rain issue here as well. Is it know issue?
ver b57
for the last poster, that problem should be gone on 2nd august, I would presume
for jobera, which version/build of WD?
Hi Brian
Its WD 10.37Q build 37
regards
John
that might be the problem, using that version
you need to be using a more recent version
also, do you have set to use the console rain totals by any chance, in the weather station type setup, davis setup?
(not normaly used)
Ok, I will update WD
There is no mark at" use rain totals from console"
Hi Brian
after updating and then waiting a day for rain it seems working now.
regards
john
