I had some rainfall today and was watching my Live display. I have a Davis VP and it indicates a rain rate per hour. Live shows the same rate as a per minute rate. Is there something I need to set up in WD to get clientraw.txt to contain in/min, instead of in/hr?
the problem is WDL is not going to know…
unless Julian you set a tag in the xml file?
do you people want in./hr in wdl if you have that coming from the davis vp?
Yes that would be the only way. It would mean that you wouldn't want to change it regularly in WD as you would have to change the config tag as well. I wouldn't want the units 'hardcoded' into the clientraw as the rain rate changes units when selected via the WDL button and that would just complicate that process.
