Rain reading on Dallas 1 wire displays in the Dallas 1 wire set up screen
(XX.XXmm since program was last run
but does not display or update the WD front programme screen with rain fall
The readout for rain since last run on the Dallas configuration screen reads the right number of tips. It also agrees with the AAG software counted tips.
It DOESN’T read the correct amount of rain fall. In my case, I have supplied WD with a correction factor of 1.27 rather than recalibrate the rain gauge. This factor is not included in the displayed “inches”.
As noted by all, the main screen doesn’t see any rainfall during shutdown.
Let me know when to do this experiment again and with what version.
For now I can just look the edited number and manually increment rainfall amounts. This approach will only work if one has only one power outage. Unfortunately, the number of outages is an unknown.
in a new 10.14i, full, when you go to the dallas 1 wire setup page, it will add on the rain that was missed auto (and the correct amount too based on your rain gauge resolution settings)
