I seem to be having issues with sending data to wunderground. Weather display does not appear to be sending data anymore, and if I go to do a test send, it sends the same readings everytime, regardless of what the readings truely are. Anyhelp…
rob
rob
what does it say under view, ftp log, view full log… it should say something about wunderground :?
what does it say under view, ftp log, view full log..... it should say something about wunderground :?
This is what it says…
Start Time/date:8:40:25 AM 9/7/2004
Permanent connection selected
Checking for what else to do…
there are 1 more things to do
Wunderground connected status: OK
Wunderground complete
Finshed email agenda
Finished email agenda, no ftp items to do…
this is a forced upload…it does not appear to be uploading automatically anymore for some reason. I have updated to SP2, I have turned on and off the firewall, no changes either way.
Help
Also, If I go into the Program error log, it looks like this
ERROR: Access violation at address 008BC64F in module ‘WeatherD.exe’. Read of address 00000364 at time/date 8:49:00 AM 9/7/2004
that error will be stopping the update…
i have a few report of that error…
not try a restart of wd and or a pc reboot
(its a memory access error)
that error will be stopping the update... i have a few report of that error... not try a restart of wd and or a pc reboot (its a memory access error)
I’ve tried a reboot, a reinstall over current version and neither worked
rob
is that error keep repeating…?
try turning some things things off maybe until it stops, to try and pinpoint it
which verison of WD again?
is that error keep repeating....? try turning some things things off maybe until it stops, to try and pinpoint it which verison of WD again?
The latest version, the problem is I do not know how long this has been happening. The data that I force it to send is the same reading all the time regardless of what my weather station or weather display says
is the data on the graph on the main screen updating?
( i suspect not)
is the data on the graph on the main screen updating? ( i suspect not)
yes it is, the graph is accurate, the data stream out is not
rob
the wunderground data uses the 12 hour graph data…
is that updating ok?
re the actual data sent:
you can see it, in the registry, i.e wdisplayftp.ini, in the wunderground section,
and also in the wdisplay.ini file (from C:\windows or C:\winnt)
[Wunderground]
Url=
,maybe checkit there
i will also add what is actualy trying to be sent to the wunderground setup page too
the wunderground data uses the 12 hour graph data... is that updating ok?re the actual data sent:
[Wunderground]
Url=
How would I purge data files…or should I just uninstall the program and reinstall it fresh. This problem happens to anything I send data out to and the data file it sends is always the same readings, but not what is being recorded.
Let me know
rob
in 10.17, the actual data sent to wunderground is shown at the bottom of the wunderground setup screen…check that too
to reset data:
exit wd
then delete the file latest.inf from the datafiles folder
then restart wd
then go action, convert wd log files to graphs…then click on convert
to reset the data used
in 10.17, the actual data sent to wunderground is shown at the bottom of the wunderground setup screen...check that tooto reset data:
exit wd
then delete the file latest.inf from the datafiles folderthen restart wd
I’ll try that, another thing that I noticed is at the top mine now says
“Weather Display 10.17a -Client (comm port disconnected)”
Is this part of my issue?
let me know
rob
exit wd
to reset the data usedI’ll try that, another thing that I noticed is at the top mine now says
Is this part of my issue?let me know
rob
Sorry, I figured out that problem, but still will not send data
yes, that means no data from your station…
now, have you checked the actual data string at the bottom of the wunderground setup?
also, check you dont have share the datafiles ticked in the extra/misc setup (see under setup)
yes, that means no data from your station...now, have you checked the actual data string at the bottom of the wunderground setup?
seems to be fixed now…the problem was apparently something to do with the weather talk setup under control panel. A feature that I have not played with for months. Anyway, hit the reset button under it, hit ok, hit save and exit, and presto, all fixed.
thats good news
not sure why it suddenly decided to have a life of its own!
