Problems with version 9.0
I hope you might me able to help me. I have an older version of Weather Display. Version 9.0. In the real time graph, I was able to graph outside and inside temperatures. I clicked on the plot average speed/rain, which took away the ability to chart my indoor temp. I cannot get it to shut back off. I have tried everything, including erasing the whole program from the computer and re-installing it. I have resorted to downloading a new version from the internet, but I do prefer the older version. Also, my weather station on the new version is not listed, and have not found the station that is completely compatible with mine to make the software work completely. I currently have the Radio Shack WX/200 or Organ Scientific. Can you suggest any solutions to this problem? Thank you, Brad K
when you erased the program did you also take care of the wdisplay.ini ?
What does work for me on occassion, is to go into that file manually. It is located in two places - one in the program and the other under the windows location( do a search for it and change all).
then go into it , it will be a text file and manually change settings. It should work. You can also install the old version to a different folder, such as wdisplay2, 3 etc…
then copy your data and log files into that , then set your config and tah dah.
Now your short cut probably will be set to your version you hate, but still you can either change the icon, ( right mouse toproperties and change the location, ) or make a new short cut and things should be fine.
OH yes, you need to do the following in the new directory make a blank text file that is just name it but it has nothing else in it like wdX.txt where x is the wd directory number such as wdisplay4 becomming wd4.txt and things should be happy.
OK, fellas what else did I need to tell him.? Like keep a every copy of the previous versions in nifty labeled files like I do?
After setting that setting, and restarting, did that fix it?
yes, the setting for this is in the wdisplay.ini file, which is in c:\windows or c:\winnt
and the setting is
Real time graph’,‘avg speed/rain’
latest version stil lists the WM918/WX200 near the top of the station list…
it just now has a small icon next to it
what do you like better about verison 9?
