Problems with historic data with 9.97d
I loaded 9.97d and now all my historic data is not reporting. The yearly rain has been reset to 0.00, the monthly rain has been reset to 0.00. Looking at the daily report it now starts at 11/24 and has no history from before that. Can someone help or tell me how to fix this issue.
Upgraded from 9.97c.
Windows XP Pro
Thanks…
check under view, program errror log for any error there at start up
also, you should have back up data, in the databackup folder
as a zip file (date stamped)
it contains the wdisplay.ini file, from c:\windows or c:\winnt,and the current logfile and data file
if you can get those before this updated (which happens just before 6am, auto (unless it not set to do so (it is by default))
you can get the old rain values there were logged in the 112003lg.txt file too
summary:
if there is a error under view program error log at startup, then email me your wdisplay.ini file from c:\windows or c:\winnt
