I am trying to follow the instructions here https://pwsdashboard.com.
Tried clicking on download full latest version.
Prompts with a form but cannot get passed entering a website URL.
The website will be www.sloan-home.uk
get
rror occurred: Maximum (1) redirects followed
Your data:
[name] => Keith
[email] => [email protected]
[email_check] => [email protected]
[region] => europe
[datasrc] => wf
[url] => www.sloan-home.co.uk
Hi Keith,
The full error message is
URL for your website seems invalid. Needs manual checking. (54)
Error occurred: Maximum (1) redirects followed
If I try with [url] => https://www.sloan-home.co.uk
I get another message
Error occurred: OpenSSL/1.1.1p: error:14094438:SSL routines:ssl3_read_bytes:tlsv1 alert internal error
Seems my server is unable to communicate safely with your website/webserver.
You could maybe start with installing but getting updates would be impossible as that is a question and answer session between your and my server.
Please check with your web-hosting company what could be the cause.
Also unzip this script and put it in the root of your website.
This is the frist script executed after install of the dashboard.
If does some other checking to display possible problems also.
startHere.php.zip (3.3 KB)
The info you show as being inputted is using .co.uk but your web site uses .uk
Hi hcorrin,
Thank you for spotting this.
I tested using the www.sloan-home.uk and all is 100% OK.
So @KeithSloan can download when using the correct link to its website.
