Problem with the graph-intervals
Hi all!
I have a problem with the interval of the current 12 / 24 / … graphs. E.g. The 12-hour graph is in reality a 14 hour one, the same problem with the others.
The 12 hour graph: as you see, the time span is 14 hours.
This also causes problems with the Trend - image, e. g. yesterday-same-time-values are calculated incorrect.
Has anyone similar problems?
Does anyone know a solution?
Thanks in advance,
Michael
PS: I am using WD 10.37P build 95
Well there is a Graph Interval setting under Control panel - Graph Setup however the choices are 3 -6 -12 -24… No 14 or 15 hmmm…
Yes, I know. Hmmm. It seems to me strange too.
It looks to me as though the time-lines are not equally spaced…those between 13 and 17 are somewhat narrower than others…maybe that is why the extra 1.5hrs has managed to get into the graph overall width. I’ve seen similar when the PC CPU has been overloaded.
looks like you have been missing data points
you can see that by the hour lines being closer together at times compared to other times
so with missing data you end up with what you are seeing
what speed pc and how much memory?
→ munrobaggins beat me to it…
Well, my PC is not fast, it is a Pentium 2 (i don’t know the mHz) with 256MB RAM and Windows 2000. There runs only WD on it.
well, that will be the problem…
are you able to add more memory to it?
I will look, what I’ve got at home.
I’ll tell you then.
Above error or program log occured at :06:01:31 29/09/10
Current warmest day value (oC) 10.0 18:00:05 29/09/10
Above error or program log occured at :18:00:05 29/09/10
Resetting coldest night values 18:01:31 29/09/10
Above error or program log occured at :18:01:31 29/09/10
Reset overnight minimum temp 21:00:00 29/09/10
Above error or program log occured at :21:00:00 29/09/10
Reset overnight minimum temp 21:01:00 29/09/10
Above error or program log occured at :21:01:00 29/09/10
Normal daily resetting wind/temperature daily value , day: 30
Above error or program log occured at :00:00:00 30/09/10
Normal daily resetting rain daily value , day: 30 rain today 9.0 mm
Above error or program log occured at :00:00:01 30/09/10
Current coldest night value (oC) 8.6 06:00:05 30/09/10
Above error or program log occured at :06:00:05 30/09/10
Resetting warmest day values 06:01:31 30/09/10
Above error or program log occured at :06:01:31 30/09/10
Current warmest day value (oC) 10.4 18:00:05 30/09/10
Above error or program log occured at :18:00:05 30/09/10
Resetting coldest night values 18:01:31 30/09/10
Above error or program log occured at :18:01:31 30/09/10
Reset overnight minimum temp 21:00:00 30/09/10
Above error or program log occured at :21:00:00 30/09/10
Reset overnight minimum temp 21:01:00 30/09/10
Above error or program log occured at :21:01:00 30/09/10
Normal daily resetting wind/temperature daily value , day: 1
Above error or program log occured at :00:00:00 01/10/10
Normal daily resetting rain daily value , day: 1 rain today 0.2 mm
Above error or program log occured at :00:00:03 01/10/10
Current coldest night value (oC) 5.5 06:00:12 01/10/10
Above error or program log occured at :06:00:12 01/10/10
Resetting warmest day values 06:01:31 01/10/10
Above error or program log occured at :06:01:31 01/10/10
Current warmest day value (oC) 9.4 18:00:10 01/10/10
Above error or program log occured at :18:00:10 01/10/10
Resetting coldest night values 18:01:31 01/10/10
Above error or program log occured at :18:01:31 01/10/10
ERROR: Not enough timers available at time/date 21:07:33 01/10/10
Above error or program log occured at :21:07:33 01/10/10
ERROR: Not enough timers available at time/date 21:21:42 01/10/10
Above error or program log occured at :21:21:42 01/10/10
ERROR: Not enough timers available at time/date 09:56:18 02/10/10
Above error or program log occured at :09:56:18 02/10/10
ERROR: Not enough timers available at time/date 00:09:43 10/10/10
Above error or program log occured at :00:09:43 10/10/10
ERROR: Not enough timers available at time/date 09:01:42 10/10/10
Above error or program log occured at :09:01:42 10/10/10
ERROR: Not enough timers available at time/date 10:11:48 10/10/10
Above error or program log occured at :10:11:48 10/10/10
ERROR: Not enough timers available at time/date 15:06:58 10/10/10
Above error or program log occured at :15:06:58 10/10/10
ERROR: Not enough timers available at time/date 17:11:51 10/10/10
Above error or program log occured at :17:11:51 10/10/10
ERROR: Not enough timers available at time/date 18:56:46 10/10/10
Above error or program log occured at :18:56:46 10/10/10
ERROR: Not enough timers available at time/date 07:11:47 11/10/10
Above error or program log occured at :07:11:47 11/10/10
ERROR: Not enough timers available at time/date 10:06:42 11/10/10
Above error or program log occured at :10:06:42 11/10/10
ERROR: Not enough timers available at time/date 13:55:06 11/10/10
Above error or program log occured at :13:55:06 11/10/10
ERROR: Not enough timers available at time/date 14:08:35 11/10/10
Above error or program log occured at :14:08:35 11/10/10
ERROR: Not enough timers available at time/date 00:09:41 12/10/10
Above error or program log occured at :00:09:41 12/10/10
ERROR: Not enough timers available at time/date 14:26:51 12/10/10
Above error or program log occured at :14:26:51 12/10/10
ERROR: Not enough timers available at time/date 15:01:47 12/10/10
Above error or program log occured at :15:01:47 12/10/10
ERROR: Not enough timers available at time/date 15:51:48 12/10/10
Above error or program log occured at :15:51:48 12/10/10
ERROR: Not enough timers available at time/date 16:52:07 12/10/10
Above error or program log occured at :16:52:07 12/10/10
ERROR: Not enough timers available at time/date 17:56:48 12/10/10
Above error or program log occured at :17:56:48 12/10/10
ERROR: Not enough timers available at time/date 22:51:44 12/10/10
Above error or program log occured at :22:51:44 12/10/10
Access violation at address 004054E2 in module 'weatherd.exe'. Read of address 00000290
Above error or program log occured at :00:11:14 13/10/10
ERROR: Not enough timers available at time/date 09:56:45 13/10/10
Above error or program log occured at :09:56:45 13/10/10
ERROR: Not enough timers available at time/date 12:16:45 13/10/10
Above error or program log occured at :12:16:45 13/10/10
ERROR: Access violation at address 0111C1AA in module 'weatherd.exe'. Read of address 00000290 at time/date 02:43:03 15/10/10
Above error or program log occured at :02:43:03 15/10/10
ERROR: Not enough timers available at time/date 07:31:53 15/10/10
Above error or program log occured at :07:31:53 15/10/10
I’ve found an error-logfile. It says “not enough timers available”. Could this be the reason? And the solution?
Btw: the time of the 12-hour graph grows longer and longer. If you look at the graph above, you see, that it is about 15 hours now.
that error does point to a lack of PC resources, yes
I think the best solution is to buy a new PC. The old one costed me 30
I use a Atom netbook, they are cheap these days
but I added in more memory too…comes with windows 7 starter
works good as
