Problem With Temperature Reading with APRS Lite Version
Hello To All,
I’m new to the community and the Weather Watch software. I have the La Crosse 2010 weather station and the 2010-13 data logger/PC interface. I’m getting the right temperature readings on the main LCD console from the inside and outside wireless temperature/humidity sensors.
But the 2010-13 logger is sending temperature, humidity and dewpoint data to the Weather Watch software that’s incorrect. I have the APRS lite v8 and am also trying out the v10+ demo and the temperature, humidity and dewpoint readings are all wrong.
I’m not sure if the logger has a problem which I doubt because the wind speed/direction and barometric pressure readings are correct or if I’m overlooking an adjustment within the software. Temperatures are running approximately 45 deg. F to low.
Any help would be much appreciated. BTW this is a CWOP station #CW2111.
this is the wrong part of the forum, you should be in the questions section…
now, in the ws2000/ws2010-13 data setup and information screen, do you have the outdoor sensor number to use set correct?
e.g set it as 1
also,for the ws2010-13, you should be trying the latest full version trial, it works really good now with that weather station type
also, the program is called weather display, not weather watch, but thats Ok… :wink:
