Privious Versions?
Seem to remember seeing a link to a pge to download previous version.
Does it still exist?
If so can somebody post the link
Regards
Brian
did you have a particular problem?
10.12u fixes a gltich with the forecaststation icon
i had left some debug code in by mistake in a revised 10.12t
Brian
Late last night after loading version T and sorted out my firewall I noticed that the main screen gif was not being uploaded, the file was being created.
If I pressed the “Now” button in the custom upload screen then the file was uploaded. But did not happen during the set times.
I re-installed version Q and all was well so I wnted to try Ver R or S which cures the Solar display in the 48 & 72 Hour gifs
Seem to remember seeing a link to a pge to download previous version.Brian
[http://www.littleswitzerlandweather.info/xfr/WD/](http://www.littleswitzerlandweather.info/xfr/WD/)
CaptDilli
Thanks for the link,
What web cam are you using?
i just did a quick test with custom over ride in 10.121t, for the screen image, and it uploaded it ok…
so i am not sure what is wrong there, for you…
maybe check the remote file name in the custom screen setup?
Seems to be ok now, so not sure what was happening.
Downloaded Version U also OK although the tite bar still says Version T
Regards
Brian
oops, my fault re the version number!
fixing now (will upload 10.12v)
CaptDilli ....What web cam are you using?
Hi Brian, I use a Logitech 4000 camera inside the house looking outside. It is USB with 3, 16
