I’ve written loads of PHP scripts over the years to run on my own servers where I know the permission structure and so what’s needed, but as far as I recall I’ve never written scripts for others to deploy on their own web servers so I’m looking for a bit of advice from those who have gone before me.
What permissions would you expect data files to have to allow them to be read and written to by a PHP script in the same directory when the script is being run by the web server process? I’d think 66x would be OK (owner and group read+write) assuming that the web server process that’s running PHP is either the owner of the directory or is in the group that owns the directory? Is that a reasonable assumption for most web servers that you’ve had your scripts used on?
It’s a bitwise arithmetic AND so I wouldn’t expect the number format to affect it at all. In my simplistic mind the numbers are converted to binary and then bitwise ANDed using registers, with the result being compared to the right side of the !=
