parse error
I’m setting up a new sun/moon page using the getraw.php script. I tried a simple test page and it worked fine, but on the sun/moon page I get an error:
Parse error: syntax error, unexpected T_REQUIRE_ONCE in /home/annmarie/…/…/sun-moon2.php on line 3
What could be causing this? My web server runs php 4.
Would you post the starting PHP code for the page up to and including the line 3 so we could have a look. It’s probably either an unclosed quoted string or a missing semi-colon on the end of the prior PHP statement.
Ken
Here you go:
<? php require_once 'getraw.php'; $wxdata = get_raw("wx2.html"); ?>
Ta :slight_smile:
Just change
to
 require_once('getraw.php');
or to
 include("getraw.php");
Should work then…
Ken
Strange, I tried both codes but ended up with the same error :?
You might try changing
<? php
to
<?php
(take out the space between the ‘?’ and the ‘php’.
Ken
That did the trick, thanks Ken!
