Oops....Bigtime...!
While messing around with the WD software, for some stupid reason, I decided to set a ‘Setup Password’. Well…, It will not accept the password I set to get back into setup after WD starts. Setup is completely greyed out, and it will not take the password I set. Is there anyway to reset this password?
Thanx ahead of time
Drmwalkr
This thread will answer your question http://www.weather-watch.com/smf/index.php?topic=3466.0
Unfortunately this looks like just a edit for a password set to for exit function. This isn’t a solution for a forgotten ‘Setup’ password’. For some info I haven’t included before I’m running WD 10.13x.
Thanx for all the help…
Drmwalkr
Sorry, finally found the reg. key and got everything back to normal.
Thanx for the help
Drmwalkr
the other way is to create a file called setupon.txt. where you have wd installed, and then restart the program :wink:
