vfs:cant find ext3 filesystem on dev ide(311)
mount:erro 22 mounting ext3 flags freeing unused kernal memory:136k freed
kernal panic:no init found . try passing iunit:option to kernal
help!
this is my linux HD that i put into my main PC…
maybe i should try it again on the original pc (that has now got w2k running/updating the weather at the old house (but which has a problem i am trying to fix))
i got to work
it has to be on IDE 0 and not IDE 1 channel
i could see my windows HD too in linux (which i set as a slave drive)
and i could copy files to the clip board from it
but it would not let me write to that HD…
so i am stuck with trying to get the latest linux version, to fix the clientraw.txt file , uploaded…
i do have a cd writer…
is there some linux cd writer software?
KB3 is usually installed by default by most Linux distro, it is an GUI burner, just like Nero or the like…
What is the format of your win drive? If it is NTFS, that can be a problem. However, if it is fat, you should be able to write. If you are in windows, you can use this program http://uranus.it.swin.edu.au/~jn/linux/explore2fs.htm
